Getting my latest project together, a 1986 KD80 (rotary valve engine).
It starts, but will only idle...if you give it ANY normal throttle, it bogs. IF you are VERY light and gradual with the throttle, it will rev up nicely. But i mean you have to nudge it up.....
I checked the float level already. It also seems to be spitting raw gas OUT the carb. I know these things have an inborn negative pulse issue but it should not throw gas out like that. You can feel the puffs coming out the carb too.
I pulled the carb and put my palm over the intake hole, and then kicked it over. The vacuum pulling against my hand was not as strong as I think it should be, and I also I felt the air coming back out against my hand also.
Anybody got any ideas? Im thinking low compression off hand...have not measured it-dont have a gauge that works although it feels pretty good.
