do you mean the bike will not move??
the plates are wore out-
or the clutch basket- the plates go in might have grooves wore in the edges -- this keeps the plates from moving in and out right--- there called chatter marks ,you can file them smooth again if its not too bad-and it will be fine
prolly needs new friction plates the "fiber" ones
if so - part number-38-646-$56.99-this is a vesrah kit from dennis kirk-1-800-969-7601-or
38-2045-$37.99--this is a ebc kit
if you need a better basket- try a salvage yard- mabe dirt cycles-1-508-478-5700
