I need to reassemble my 96 kdx clutch the engine has just had a rebuild after a gearbox failure.What I need to know is where the two washers that are on the input shaft should be put.Must the one go behind the clutch basket agianst the input shaft bearing and the other on the outside behinde the retaing nut and the clutch torque specs if possible.Any help here would be highly appreciated.
