gertie6car
- Apr 12, 2008
- 16
- 0
Hi, I recently bought a kdx200E2 as a rebuild project, the bike itself is in very good original condition but has been well maintained. I got it real cheap as the previous owner had damaged the case around the boss for the rear of the kick starter shaft. I was told he had come off, flooded the engine and had got to enthusiastic trying to restart it?! Anyway the current situation is the engine is out and stripped and I have l bought and stripped a second hand motor which had a lousy top end. I am now looking for advice on the following points and hope some of you will help me out!!
Are the cases matched or can I use the non damaged case from the second hand engine with the original left hand engine case?
Is it possible for an amateur (reasonably experienced with engines) to reassemble the crank into the mains without having access to the kawasaki tools referred to in the manual? I can make up a tool to pull the crank into the right hand bearing without too much trouble but the left hand crank case is pressed into place with the right hand bearing supported and using a "special" tool to support the crank (fits between the flywheels to maintain alignment.
Don't want to use an engine shop unless I have to but equally do not want to screw up the crank and new bearing etc.
Advice would be appreciated. Cheers Gert
