Just purchased stiffer springs for my 2002 KDX 200, (I am 185 lbs.)
When I asked about the PVC spacer supplied with the springs, I was told "Just Use the old steel spacer" I replaced the springs and used 7 wt fork oil. Now after a bit more research I understand the PVC spacer is used since the new springs may not be the same length as the stock ones and also to be used to dial in the forks to perfection. Should I pull the forks apart again to see if the springs are the same length or should the springs be somewhat close? Help!
