Where did you get that air screw? It looks to be mounted on a spring the projects it an inch or so from the carb body...the air screw on my carb doesn't look like that (PWK35 on '03 200).
Notice those hex head machine screws he has holding on the bowl not those phillips head oem ones! You can tell he adjusts his carb and how important it is to him to adjust it properly. Cheers John
I never thought of hex head screws there, that makes a lot of sense, thanks for the tip! (I've already had to replace a few of those screws because of a cheap screwdriver...)
I could take the screw to a parts shop for matching, but would you tell me what dimensions are required for those hex screws? The parts diagram on the Kawasaki site is not particularly helpful here...
Allenhead screws would be even better but my home improvement store does not carry metric allens
I changed the screws on my DR last week only to find that I could not get a socket on the bolt head
I believe the size is a 5 or m5, but I find it easier to just take one screw with me and match it with a nut. If I can't get the exact length, I just buy longer ones and cut them down to size with a Dremel tool. (buy extras)
Another thing, be sure and use a little antiseize on the threads and they will come out a lot easier next time
Yep...and get a ball-end allen to get to wrench on 'em with.
I've used a hacksaw one too many times on those steenking bowl screws. By all means at the very least take them out soonest and put some never-seize on them.
I don't recall the metric numbers either. You may find them only in stainless. Probably depends on the particular hardware store you're looking in. I use stainless on my kdx.
