I know reading and responding to jetting posts gets real boring...but if you have some FIRSTHAND advice...I would appreciate it.
200s and 220s are very different.I need the 220 jetting tips. looking for a way to eliminate some 0 to 1/4 throttle, 4-stroking, loading up, going bup,bup,bup as it throttles up...whatever you want to call it.
I have super performance on rapid throttling, but do not like the bupping under light acceleration.
Just looking for info to work with the stock 33mm carb.too cheap/financially embarassed to pop for the bored carb.
mine is 97 kdx 220 145/42, r1173l needle 2nd clip from top,AS 2 turns out @ sea level,br7es plug. Even if it did not work for you, I would like to here what you tried. leaner needle? or just a leaner pilot? Has anyone tried a #6 slide,or BEQ or 1174K needle to correct the sympton described above??
thanks gentlemen
thanks gentlemen
