ReubenL
- Nov 27, 2005
- 36
- 0
just wondering if anyone knows for sure the differences between the '89-94 200cc generation and the 95-up 200cc generation... and the differences between the 200cc and the 220cc. I know the carb is 33mm on the kdx220, 35mm on the kdx200... and the cylinder is (somehow) different-
my immediate question is whether the bottom ends are swap-able? can I take a '96 220cc top end, and use it on an '89-94 bottom end?
I've discovered that the right-side engine cover (not the small clutch-cover, but the larger casting) gasket is the same- but I also know the water-pumps are profoundly different. I'm not afraid of a little machine work, if it's a minor difference here and there...
anyone know for sure if the tops/bottoms can be interchanged?
sub-question: can the engines be changed from chassis to chassis?
meaning, are all the motor-mount locations, and intake location, exhaust port location, etc. the same?
thanks!
~Reuben
thanks!
~Reuben
