macauley
16
I have recently purchased a 2003 KDX200 and have a little trouble with the low end sometimes as it stalls occasionally and it a bit boggy in first gear. Do you have any suggestions? I run Spectro mix about 40:1 with the factory plug (BR8ES).
Another issue is that the clutch seems fine when riding, but if the bike is "off" and no matter how much I adjust the clutch, when it is disengaged, while in gear, the bike won't move just like it drags when the clutch is engaged. What could this be?
ericlachance
171
Check your jetting... That sounds like a simple jetting problem. What does your spark plug look like? And as for your clutch 'problem' all bikes do that(as far as I know) It's normal. A bike clutch has to be spinning for the plates to fully disengage from each other. Plus, on a older bike, Grooves form on the clutch basket causing the plates to not fully disengage. I am no expert, but I never reply unless I am sure of what im saying. Hope this helps.
