mark_england
156
ive just built a kdx/kx hybrid.
wonder if anyone can help out.
im rebuilding all the waterpump seals bearings etc
in a 1990 200 sr engine
does the sr use a mechanical water pump seal?
and does this differ from the standard kdx ? does that use the same configuration of seals etc?
cheers
ronhawker
8
Make sure you check the impellar shaft for wear too. The seals can wear grooves in the shaft that replacing the seals only will not stop the leaking.
boyo
17
Check this site, it is japanese, but not that difficult to use.
Choose motorbikes and than the bike you have.
This site is good, because you can find all the parts you need for the "sr" and also for the "normal" bikes, so you can compare the partnumbers.
www.kawasaki-motors.com/parts_cat/
Regards,
Robert
yzfjim750
21
"R" V's "SR"
Hi there, just go and order a seal from the same year "R" model from your local dealer as the motor is identical.
Regards,
Jim ;)
