Keihin fcr 37 carb : Choke and hot start.
Krossipoiss
93
I have bought 2 fcr carbs and i'm bit confused now. One of them has choke in upper hole and hot start under it and other has hot start in upper hole... Why is so and which one is correct ?
pesky nz
296
crf 250 r in showroom has choke under hotstart and this makes sense because choke must get fuel from bowl below while hot start only lets air bypass the slide
Krossipoiss
93
Which one is correct ?
mideastrider
827
I've never saw a hotstart on the bottom hole. But then again i've not seen everything. Give carb parts warehouse a call they can tell you for sure.
