Graedat
7
Hi guys i have a 90 model kdx 200 and it has the 28mm PE Keihin carb on it.
Anyone know what the standard needle is for this carb and what needle would suit for my bike which has the open airbox and pro circuit pipe.
The needle in the carb is worn and i cant read the code on it.
Graedat
OldDirtKDX
58
Needle
Try contacting SUDCO, I have had good luck with them when it comes to getting specs on older bike carbs. The dealer will also have it in their books.
Rogerdodger
13
Needle
The standard needle is a N68K. However, I've no idea what needle would suit a Pro-circuit pipe!
I'd recommend that you get a 35mm PWK carby off a E series KDX from a wreckers. I fitted one to my '89 KDX F1 and it really made a difference to the performance, even with the standard exhaust pipe left on!
Cheers
