Had a '92, now rebuilding an '02. New plating, Wiesco pistons
Boyesen reeds and so on.
The KIPS is a little different than previous, but not impossible.
After assy. just how 'smooth'' should the movement be?
When I turn it by hand it seems tight. Applied the right lube to all required points, all fasteners are to specs, even replaced the seals in the jug and put a new o-ring on the exhaust valve arm. It just seems tight, now maybe the engine heat and operating temp will loosen things up. But I would like some input before I put all back together and find out I going to do it again.
2nd Question - About the KIPS shaft into the motor.
Exactly how does it come out. I removed the screw and pin.
Does this come out without taking the engine part? I would like to inspect the bottom section.
Thank you in advance for your support.
