I own a 2001 klx 300 great bike!!! until!!!
I have @ 3000 miles on the bike use castrol 10 40 w synthetic
motorcycle oil. change oil every other ride @ 200 to 300 miles
heres what happened before trip changed oil and filter . rode @
150 miles on day one next day checked oil level showed in mid glass ok. warmed bike up took off down road when shifting into third gear engine locked up bummer!!. At home pulled apart found
exhaust cam had seized in bore ? lack of lube/ rechecked oil level
and found at low mark in glass. pulled motor all the way down found no other damage or reason for failure. At this time took engine to jerry leighton at four stroke works very good pepole!
He also only found normal wear I had him go through engine he was able to save head. Installed stainless intake valves seals, shift star rework , and some rework of lower end for better reliablity, engine run's better then ever but what happened???!!!!
p.s. jerry told me to run oil level to top of glass and keep it there!
