- Jul 31, 2000
- 2,082
- 0
hello all,
working on a '94 KLX, all stock suspension as far as I know. I took loose the caps on the forks to add some oil and noticed that the previous owner had installed PVC spacers and they're now crushed. Am I correct in assuming that they installed the spacers to increase the preload in the forks? Anyone know what a good oil level is for these forks? (I prefer mine a bit stiffer). Also, compression on the rear shock is cranked all the way in (spare one notch) and it's still too soft, what could be the fault here? Possible solutions? Thanks much in advance.
