Knowledge base and parts available?
tpbeebejr
18
New member here. Is there a knowledge base website for the Honda XL350R (I have a 1984)?
Also, is it still possible to buy OEM and aftermarket parts for my 1984 bike? What are the best few online sources for a Honda of this age?
RM_guy
Moderator
7,046
208
North East USA
tpbeebejr
18
Thanks, RM _guy. Having a hard time finding float bowl o-rings.
Tom (tpbeebejr)
12120
bowl orings
I had to buy complete carb kits to get the bowl o-rings. Probably need some of the other little pieces anyway if you take the carbs all the way apart.
Chris
tpbeebejr
18
I will soon be posting a simple method to measure what size a regular old cheap o-ring needs to be to substitute for a float bowl gasket when you can't buy the gasket. Much better than buying TWO carb gasket kits for about $25 each.
It might be worth noting that the o-rings used in Japanese carb are typically made from fluoroelastomers with Viton being a common one in my experience.
You're a chemistry guy so I doubt I'm telling you anything you don't know, but for anyone else reading this, the above is important because Viton is well known for its heat resistance and stability when subjected to aggressive fuels and chemicals. Generic o-rings made with natural rubber or other less suitable compounds will tend to break down and leak when subjected to the heat of engines and the solvent properties of the hydrocarbons, ethers, and alcohols in modern fuels.
Good carb kits and the o-rings in them are usually worth the money even it the cost seems high.
Just thought I should pass that along.
tpbeebejr
18
Rich, you are right on all counts. I study polymers as part of my research and indeed one must match the o-ring material to the application. Viton is excellent for its chemical resistance to petroleum-based fuels, as is BUNA-nitrile at about half the cost. The PDF that I referred to above is now ready for posting, but I was disappointed to find that the size limit for PDF files here is 73kB or something incredibly small. Can I please send you my PDF file (1.7 MB) so that you can read it and decide if it is useful for this forum? Then you can use your administrator privileges to override the posting limit if you see fit. Please tell me how I can send the file to you.
Thanks,
Tom (tpbeebejr)
