Hi Guys,
I hope someone could possibly point me in the right direction here - because I'm running out of ideas...
The problem I'm having is that the clutch is engaging at the last 2 -3mm of the clutch lever's travel (right at the end). And when the bike gets hot (Riding rocks, etc) then it gets worse)
I've done the following so far as attempts to address the problem :-
I've adjusted the lever.
I've replaced the Plates & Discs (They all in the right order).
I've replaced the Axial needle bearing on the end of the Push rod.
I've bled the system. (And am using the correct mineral oil)
I've checked the outer clutch basket for grooves, and filled the edges smooth (less than 1mm was removed in bad spots)
The clutch is not slipping or shuddering ... just taking very late.
Anyone know what the cause could be?
Thanks in advance!
Thanks in advance!
