KTM 250XC-w Plug
mideastrider
827
Does any spark plug company make a shorter plug for the KTM 250xc-w? I'm sure someone has run into this problem but when you get the plug in the head the top of the plug is so close to frame its a pain in arsh to get the wire on. I just wonder if there is a plug in the same heat range that's shorter. Just trying to my life easier.
jake760
74
My KTM takes a BR8ECM, I believe it is shorter than the ES and EG plugs. What plug do you have in there now?
mideastrider
827
BR8ES is what I took out. I replaced with a BR7ES because that's what I had. I will look into the ECM. Just 2 or 3 mm's shorter would make a big difference.
mideastrider
827
dirt bike dave said:
Eyballing a spare ECM vs. a BR8ES, the ECM is probably 5 or 6mm shorter.
That would do it for sure! I was checking online and it seems they are quite a bit more than a standard plug. MSRP is like 11 bucks. I guess it will be worth it not to use a shoe horn and vaseline to change a plug.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
