demographic
- Jan 21, 2002
- 128
- 0
On my Kx 500 the cylinder head has only one water pipe leading to the left radiator then the water goes across to the right rad then down to the water pump. Is your KTM the same apart from a thermostat between the two rads? If so, do you know how long is the thermostat? I have been looking into fitting an in line thermostat to my bike as it is geared up for road use (it has lights and so forth on it)and gets a lot of air through the radiators also if it helps warmup then next door don't have to listen to it for as long. Any information that you can give me would be apreciated. Cheers
