liverpoolphil2130
- Feb 24, 2005
- 24
- 0
Hope you can help me with this
My 87 KX is currently running the best it has since I have had it (new cylinder head, powervalves, carb service, air filter etc) BUT it seems to rev past itself at 3/4 to full throttle. Its great going through the gears (in terms of power) but its seems to be most noticable in 5th and 6th when, if you give it too much throttle, it revs much higher than it should
This problem can be over come by simply going easy on the throttle and being carefull not to give it too much through each gear but I am wondering if this is 1) normal? and 2) if anything can be done to sort it?
I have tried the timing both advanced and retarded (and inbetween) and this DOES have an effect, but only on power delivery and not the over-revving problem
Any advice appreciated
