Hi to all you KX fork conversion graduates. My question is kind of specific, and I haven't found anything in the search forum about it. Has anyone found lower fork protectors that will fit 99 KX forks and clamp the brake line ( ala CR Honda style ) so that you can use the stock KDX brake setup? :clue: Almost all factory MX race bikes use this setup. I'm using 99 KX forks and they originally used the "wrap under the fork tube and then follow the fork protectors up" method of brake line routing. Help or ideas greatly appreciated!
