griffbones
- Sep 12, 2006
- 329
- 1
KX100 owners - Your jetting set-ups
I realize that no two bikes run exactly the same and there is no cookie cutter pattern for jetting, with that being said I am just currious what jetting specs (set-ups) any of you are running with your KX100, and at what temp and altitude etc..
my current set-up is as follows
Stock bike, stock pipe, stock reeds, stock everything.
40 - 50 degree temps at about 800-900 ft. above sea level
(Amsoil) 40:1 mix ratio with 91 octane pump gas
45 pilot
Air screw 1 3/8 - 1 1/2 turns out
NAPF needle 4th groove from the top
138 main jet
My son is using this bike for trail riding and he is an advanced beginner. So what are your jetting set-ups and what have you found to produce best results for you? Thanks in advance for any input!
45 pilot
138 main jet
