Britt Boyette
- Aug 16, 2004
- 280
- 0
I have noticed that our 04 KX250 can only be started when it's not in gear. It will not kick over with the clutch lever pulled. It also doesn't seem to matter where the clutch adjustment is set either as with more pull on the lever, it will try to fire off but just kicks back and wacks your foot. This bike only has about 2 hours of easy run time so I don't think it's a worn out clutch. Has anyone else noticed or had this problem?
Britt
Britt
