Hi all i,m picking up some 99 kx500 forks and clamps,what else will i need to finish the conversion.
1.can i use the kx axle and disc brake
2.kdx stem bearings
3.thank you for your help
the kx5 and the kdx use the same stem and bearings as far as I know. You'll probably need a kx5 wheel, axle, and spacers. Not sure if the KDX caliper will bolt up but I think not.
