02 220 bought used/stock everything
Wheelies inch or two off ground
good midrange power ok top end -i know stock, the bike isn't know for its top end power
compression 145psi
jetting is stock with clip on 2nd from top, Carb. was just cleaned
synthetic oil 40:1 mix which was better than 32:1 32:1 was causing way to much white smoke
spooge cleaned out of silencer
How do I get more bottom end torque besides getting pipe and other mods?
Is a rebuild in order to get more torque/wheelies? Or does 145psi indicate that I don't need to rebuild?
What should I do?
Thanks ---you guys are the best
compression 145psi
What should I do?
