Hi Fellas,
I suspect an air leak causing a high idle condition and I want to spray something around the gaskets, etc to listen for a change in idle.
Problem is that the engine is freshly painted with high temp and I know what will happen if I start spraying carb cleaner around there.
Does anyone know if quick start will peel paint as well or is it easier on the chemicals than a cleaner solution?
Does anyone have any other alternatives to these chemicals that will leave my paint job intact?
TIA
Bernie
TIA
Bernie
