Hi guys, i m ridin a 93 KLX 250. i went for an oil change today & i was shocked to see that only 500ml of engine oil came out from the engine (my machine requires 1.5L).
The mechanic told me that my bike is 8yrs & probably that is why the engine is 'drinkin' my oil.
But to my knowledge, only when the the piston ring or the valves gives way (that's when u will exprience power lose or white smoke comin out of the mufflers rte?)
He also advised to half the valve grinded wif the grindin paste to remove the carbon build up & change the piston rings.
I m quite hesitant to have it done as it is very costlly
But there again if it is safe & it reqiures to have it done, i will do it.
So guys out there, pls kindly adivse, thkz so much!!!!:(
