?Lowering with longer pull rods (dog-bones)?
rcers
95
Lowering KDX with longer" DOG BONES" ?
Does anyone know how much longer the DogBones need to be for lowering a KDX? I saw that a company called KOUBA is making 3 different sized links for lowering different amounts(apox.1"-1 1/2" and 2")I could make my own links at work if I new how much longer they need to be for the different lowering amounts. This is the 2nd time I've posted this question,"Surely somebody knows"?
THX
BOB,E.
mail me [email protected]
Fred T
5,272
E mail Kouba
and he will tell you how long his links are. I did but don't remember. I think to get an inch at the seat you need 5 MM longer rod. Stock is 112.5 so you need a 117.5 rod to get about an inch lower at the seat. Remember this changes the ratios and your spring will react like a softer spring too so if you weigh close to 200 LBS your spring will end up being too soft.
I suggest your try a combination of links and seat trimming. You can get DEVOL links that are adjustable and go to 114 MM which gets you about 1/2 inch at the seat, lower your fork tubes 1/2 inch and then cut 1-1/2 inches of seat foam out of your seat and you lower by 2 inches.
