ktm 550 mxc monster
- Aug 11, 1999
- 30
- 0
Is there a direct advantage to shimming the midvale so that it can only move say 1mm or less as compared to the 3 mm or so it moves now in my ktm fork? I don't quite understand how fluid is forced through the base valve when the midvalve blows off so easy, so will making the midvalve more active than just check force the base valving to do more work or possibly allow you to make the lsc lighter while alowing the hsc to handle the bigger sharper hits?
I could be all wrong but I am wil to learn :yeehaw:
