http://www.zippyimages.com/31211.html
Check that out... I just built it out of boredom. Its a mini PVC potato cannon, made of 1" and 3/4" pressure-rated PVC and a 3/4" lawn sprinkler valve pnuematically modified to open alot faster. This program made for calculating the performance of a pnuematic potato cannon (which is extremely accurate - it is the standard for modeling pnuematic cannons and is usually accurate within 2-3 FPS when calculating performance) says the muzzle velocity is about 260FPS and muzzle energy is about 11.5 ft/lbs at 100 PSI. Not bad for something that I made in my garage and can be filled to 100 PSI with a few pumps of a bicycle tire pump, eh?
If anyone is interested, I can build you one like this for about $50, or more if you want a bigger one (but youll need an air compressor for some of the bigger ones). This is not a for-sale add though. Im not selling this one so if you want one or want more info on making one PM/email me.
By the way, that purple stuff is primer that helps the glue melt and bond the plastic better.
