Moose Aluminum Handgaurds... can't get them on!!
Frontside720
64
Like the title said... I can't get them on.
The hole on my bar end is really small and the screws I was given with the guards don't fit. Is there a trick to this or something?
BTW... they are being installed on stock bars.
Thanks for your help.
Tazmanian
The stock kdx bars have a steel plug in the end of the bars. You can tap threads in the plugs or grind the end of the bars to remove the spot-welds to remove the plug.
RBSOB
56
Taz is correct, on the stock bars, you need to cut the bar end off to eliminate the "plug" and use the expansion type fitting that comes with most hand guards. An alternative, that I used on a stock bar, is to get a stainless steel self tapping screw/bolt, and use this, with a spacer between the throttle tube and hand guard [so throttle won't bind on guard] to bolt guard into bar plug. Worked great for me until I replaced bars. Jim G
Oct 10, 2004
163
I had to drill my bars out to 9/16 to get mine on. I only removed a small amount of material but enough to get them on
sick 96 250
1,207
I had the same problem with my moose guards. The end pieces that they come with are to big. I went back to my dealer and they gave me ones that were smaller that slid in there and worked correctly. I dont know why the one were bigger but thats how I corrected my problem
SpeedyManiac
2,374
Most barkbusters come with two mounting bolts- one for steel bars and one for aluminum bars. Aluminum bars have a smaller inner diameter and aluminum is softer so it uses two pieces that dig into the inside of the bar. For steel bars it uses a piece of rubber hose that gets squished (and expands outwards) in the bar when you tighten the bolt, holding the barkbuster on.
ScottZJ
27
It was so much of a hassel with me, I just opt to change the bars out so I didnt have to deal with the plug in the bars. Much easier to do it that way and you can always have a spare set of bars when you ride.............peace
Frontside720
64
Hm... Very interesting...
I have thought about just replacing the bars but I think I will try the cut 3/4 of inch method. I started drilling one side out but I think for the inch that I will loose it will be much easier to just cut. Is there a trick to getting the grips off? I think mine were glued onto the bars. Will I have to cut them off and get new ones or can they be saved?
ScottZJ
27
Well if you glued your grips on, more than likely you wont be able to get them off without cutting them. Mine were glued and it took a hair dryer and some plyers and putty knife to get them off. Its easier to get new grips verse saving them.
ScottZJ
27
Here is a pic of mine with the new bars and Acerbis hand protectors.
ScottZJ
27
Sorry no Loretta Lynns for me man. I couldnt get anyone to roll with me and didnt want to go by myself. I am going to have to find more bike riding buddies and venture away from my trikes. Sounds like fun though..........peace
