More Bottom end for a KDX200
NCFRC
131
Any suggestions how to get better bottom end out of a 200 ?
Even with a torque pipe , torque ring and higher compression ratio
it has only good midrange and topend.
Maybe the KIPS isn't working properly ?
The 220 we have runs great low , mid and top ,,,, if I could get a 220 top end reasonable I'd swap it over in a heartbeat.
Thanks for any suggestions
julien_d
1,788
220 is even more torquey than the 200 just by design, but the 200 has legendary torque anyway. I would try removing the torque ring. I found it killed the performance on my 200. And yes, definitely check the kips for proper operation.
porterdog
71
If you're too rich on your pilot you could be sacrificing power.
I came to the KDX from an XR400 (tractor) and an XR650R (100 mph tractor), and the only time I could complain about the KDX's torque (mine's an '06) was after I put the Rev pipe on. (Fredette torque ring took care of that)
Agree with the others, either there's something wrong with your bike, or your expectations are unreasonable :)
G. Gearloose
Pigment of ur imagination
Jul 24, 2000
709
Set the air screw for best off-idle response under load, not highest idle.
Jet the bike right and consider a different needle.
After that, learn to slip the clutch.
NCFRC
131
Were you using the torque ring with an FMF woods " torque pipe "
That's what we're running.
I'll take the kips apart this weekend ,,, I think it runs more like a 125 on the bottom and it hits hard at mid-throttle .
julien_d
1,788
I was using a modified stock pipe. Performance wise it should be pretty close to a woods pipe. I switched to a DG but have not tried the torque ring since switching. I don't want to change anything, it's perfect :D.
Have you checked on the reeds? If they are stock and you haven't replaced them, throw some boyesen 607's in. That will help the low end response considerably and you won't lose any top.
What do you mean by "higher compression ratio"? What have you done to increase compression?
NCFRC
131
Yes , it has 607 reeds .
The head was planed .015 to up the compression 1 ratio .
I hope I find something in the Kips is broken
julien_d
1,788
If the kips were staying open you would have good mid/top and no low end, much like a 125. I hope you find your problem there. If not, then I would double check the compression and make sure it's where you think it is. It could be a jetting issue as well. Either too rich or too lean on the pilot/needle jet.
theckeler
144
Little off topic, but how does one check to make sure your KIPS is working correctly. I cleaned mine all out and checked it when I did my top end, of course it wasn't running, but wondering if your able to check it when running?
julien_d
1,788
Pull the plastic cover on the RH side and watch the actuating rod get pulled out when you throttle it. If anything is broken or not moving that arm will quite likely get hung up.
theckeler
144
Cool thanks, guess I could have figured that out, makes sense... just didn't know if you could pull covers like that while running.
julien_d
1,788
The engine can be ran with the RH cover removed. It's just a dust shield really. It's a pain to get off with the pipe in the way though.
NCFRC
131
I had some time this afternoon and pulled the cover off where the Kips shaft gear contacts the exhaust port shaft . Yes , I removed the exhaust to make it easier. What I found was the shaft tension wasn't holding the exhaust port completely closed. I gently twisted the shaft with a pair of pliers and it had good spring tension so I assume the lower part of the shaft is connected properly.
I moved the shaft half moon gear one tooth ahead on the port shaft and it now holds the exhaust port nice and tightly closed.
I had the top end off this winter and I thought it was tight but maybe I didn't check it close enough. The other strange think is I don't think it had this bad a low end when we first got it out.
After reassembling , the bottom is back and the power is much smoother , no abrupt hit , which made it terrible for trail riding.
Is there any way the shaft can be slipping on the bottom ?
NCFRC
131
glad2ride said:
Did you have the head combustion shape changed any, or just had it lowered?
Did you do any other changes when you modified the head?
Maybe not textbook correct but I polished the combustion chamber for better flame travel and had a machine shop friend plane .015 off it. Yes , I just lowered it and didn't reshape the squish chamber
NCFRC
131
NCFRC said:
I had some time this afternoon and pulled the cover off where the Kips shaft gear contacts the exhaust port shaft . Yes , I removed the exhaust to make it easier. What I found was the shaft tension wasn't holding the exhaust port completely closed. I gently turned the shaft with a pair of pliers and it had good spring tension so I assume the lower part of the shaft is connected properly.
Any thoughts on this ?
NCFRC
131
mudpack said:
Interesting. In what way is it better than it was pre-polish?
Mud
A couple things ,,, pre-polish the combustion chamber is fairly rough like it was sand cast ,, so polishing it with emery paper prevents any carbon build up and the flame travel from the ignition point is more efficient.
Just a small thing that adds to much bigger overall increase .
