I have an 04 KDX200, air box lid removed, twin-air filter, boyseen reeds, and I just installed a PC platinum 2 this afternoon. Right now the jetting is 152 main, 42 pilot, stock needle. I have also set the float level on the low end. The bike STILL seems rich. Today I went for a spin at 40 degrees and 2000ft. So in the spring when I ride at 65 degrees and 3000ft to 5000ft, it will be even richer!
I run castrol TTS oil and when hot, the bike should hardly smoke. Yet is still smokes too much. It also has a bog on the bottom. If I am in the low to mid part of the RPM's and grab a handful, it just goes blug blug. Oil is dripping out of the end of the silencer and the junction between the pipe and silencer is dirty. The bike also sputters on the bottom and at idle. The top seems to be ok, but the people behind me say that I throw quite a cloud of smoke.
I am thinking going one smaller on the pilot and main, so down to 150 main, 40 pilot. Is anyone running jets that small? Keep in mind that I do ride at fairly high elevations, 3000ft to 5000ft typically.
thanks!
thanks!
