I am working on a 94 PW-50. I can't get it to run at much more than an idle. I have replaced the piston, rings, gaskets and that raised the compression from 80 to 105. I have swaped out the carb, coil, cylinder (same bore), head with a running bike (83 model)no luck. I have an 83 that I am using until I get the 94 running. It has 120 lbs compression yet when I put the that cylinder and head on the 94 I lose 15 lbs of compression and that is with a new piston and rings on the 94. What else contribute to loss of compression? The reeds? Seals? Airleak? I am running out of ideas. Oh, I tried disconnecting the harness from the throttle switch, no luck.
Thanks for any ideas!!
