Hello i just got this bike 3 days ago, it runs great so far but i am having trouble with it in 1st .
as soon as you drop it into first, it will stall unless you rev as you drop it into gear. It will also jump very slightly when put into 1st, emphasis on very slightly though.
But when you release the clutch as you give it throttle, it wants to go and lurches forwards but usually sputters , goes forwards a bit and stalls.. It takes several tries to get it going, i give it more throttle than necessary and sometimes it just catches and throws the front wheel up. But once it starts going, then its completely fine and shifts through all the gears perfect. As long as i only come to a rolling stop (dont stop completely), then it takes off again in 1st gear no problem.
Im really a bike noob but i tried to describe this as best i could. Please any advice / things i could do to fix this would be greatly appreciated.
