Hi guys,
I have posted some questions about to fix my CR 125...For members that are remembered about my problem here I am with the potential solution...
Just to refresh our minds:
- Clean air filter and air boot, NGK B8ES brown, no water in carb, crankshaft ok, rod perfect, new top end, carb vent hoses ok, fresh gas, mix 32:1 Castrol TTS, compression ok, idle perfect...
Current jetting:
Pilot 50
Main 173
2 rd clip
AS set for better response
The bike has a great response from idle to wide open in the STAND...and after to bore you with a lot of questions I have detected that my bike only bogs and begin run erratic after riding in wide open mod for 20 or more seconds and then it stops...and start after 4 or 5 kicks...Moral of the story ? My mechanic re jetted it with dirt in air filter (he confessed me...) in a track.(BTW I have been sick in home)
I know that a dirty filter will rich the jetting and will mess the plug reading...
- Can rider weight makes also a huge difference regarding the jetting ? I have more 20 kilos than him.
BTW I am going to try a large main.
THANKS ALL FOR YOUR TIME.
Current jetting:
Pilot 50
Main 173
2 rd clip
