I wouldn't add a different type to it. You should change that stuff out at least on a yearly bases. Its as easy as changing oil and the thing doesn't hold much anyway. Just drain it and put some new stuff in there.
DO mix it. General mix ratio is 50/50. Using 100% antifreeze isn't doing you any favors. The other way 'round, actually. It doesn't have as effective heat transfer properties as water, so the higher ratio af/water you use, the less heat it will get rid of.
That's why there's 'moose-juice' and such.
kdx: Thanks for the reminder. It's time to change mine!
Do you remember a thread from a while ago where the author (Sage I think) suggested using Toyota brand antifreeze as it is more aluminum freindly and used by Factory Kawasaki road racers? Or maybe it was just a dream; I got to remember to stop getting old :yeehaw:
