need help draining gas tank...
Flux3D
75
I have a 2005 yz250 and I want to drain the gas tank. Could someone please lead me through how to do this? It's probably not that hard but I just dont want to mess up my bike.
crkid33
83
turn the gas off.take the tube from the tank to the carb off of the gas tank(right where you turn the gas on/off). get a pan or whatnot turn the gas on and it will drain out.
RM_guy
Moderator
7,046
208
North East USA
If you set your gas can up on blocks (if it's not tall enough), you can put the fuel line right in the spout and drain it into the can.
wake_rider
481
Just to explain a little more if you're still not sure, turn the gas off at the Petcock (lever that says 'on, off' below the gas tank) and the tube that runs from that to your carb should have a spring clip around it. Undo that clip and put the end of the tube in a gas can, pan, etc.... then turn the lever on your petcock back to 'on.' That will do it for you.
