lake
I've got a 2001 cr 125 and started having rear brake problems. I still have a bit of brake pressure when i first hit the pedal, but the pressure seems to back off and the pedal will just keep going down. I was told it could be the seals in my master cylinder, so i completely rebuilt it but I am still having the same problems.
Any takers on what the problem could be?
ellandoh
dismount art student
2,958
well, barring any leaks , and assuming that if you can rebuild a master you probably can bleed it also , id guess you missed something.
i would disassemble reinspect and reassemble but thats just me
Matt90GT
1,517
If you rebuilt the MC correctly and still have problems, either a leak at a banjo fitting or more than likely the rear line is ballooning. Time for a new rear line.
