Need info on 2003 KX front end torque setting
KDX200Kev
161
I have 2003 KX forks and need torque settings for the following:.
- Axle Nut?
- Pinch Bolts?
- Triple Clamp Upper?
- Triple Clamp Lower 10 - 13 ft/lbs?
Thanks for helping me out.
JST122
645
KDX200Kev I have a 2003 KX 250 and I looked up the following torque specs for you in my service manual. I believe the pinch bolts that you are refering to are the front axel clamp bolts that lock the axel to the fork legs.
Front Axel: 58 ft-lbs
Front Axel Clamp Bolts: 14.5 ft-lbs
Triple Clamp Upper: 14.5 ft-lbs
Triple Clamp Lower: 14.5 ft-lbs
Hope this helps.
KDX200Kev
161
Thank you. FYI, I have heard that if you run the lower triple clamp bolts at 10 ft-lbs it will prevent binding and your forks will perform better.
