emoguitar131
- Aug 20, 2005
- 10
- 0
Okay guys, I need some help... I'd been reading up about ways to help eliminate handlebar vibration and saw that some guys fill their handlebars with foam insulation to absorb some of the vibration while riding. Well, I decided to give it a shot, and poked a 1/4" hole in the end of each grip. Then, I proceeded to fill the handlebars from each end with "Great Stuff" window and door expanding foam insulation. When it started to ooze out of the other side, I stopped and figured I would just let it expand completely, clean it up, and I'd be all set. Not the case... I clearly underestimated the expansion properties of the stuff, as I checked on it 15 minutes later and realized that my throttle was seized. Realizing my problem, I immediately disassembled the throttle. The foam had worked it's way all the way up through the throttle housing, and even to the beginning of the throttle cable. The back of the can said that the wet foam could be dissolved with acetone, but knowing acetone also dissolves plastic, I figured that would be a bad idea. I tried WD-40 but to no avail. This stuff is TOUGH. So now, I have a throttle housing that's completely covered in cured foam insulation and no way to remove it. Does anyone know of a solvent that might get this stuff off? If I can't find a solvent I guess I'll have to get in there with a little screwdriver and start chipping it all away. Any input is appreciated... thanks in advance.
