Even though I think I waited a bit too long, this last weekend with about 5 or 6 rides on the KDX-220 I tore down the rear suspension (shock mounts, dogbones, swingarm, shock pivot) cleaned and regreased every needle bearing.
Apart from re-using the old cotter pin on the rear wheel axle, everything went smoothly and by the numbers.
I did, however, run into something very very curious...
on the shock pivot piece, the pivot part that actuates the rear shock via the dogbones, I noted that there was ALOT of play between the bearing race (the steel cylinder that runs inside the needle bearings that you normally slip out to regrease) and the pivot bolt, that goes thru the steel cylinder...
Hmm, this is not clear enough... hopefully this is clearer... When you insert the pivot bolts thru the "sleeves" the bolts rattles around alot in the sleeve and are not even close to a nice slip fit... (the main swingarm bolts and bearing are a much closer tolerance, but almost all the pivot bolts fit in the dogbone assembly very loose...
My bike is still brand new with NO hard riding on it at all prior to this disassembly...
Is the tolerance in this area of the suspension supposed to be this sloppy? Without measuring, I'm gauging that if the inside diameter of the bearing sleeve is 12mm then it feels like the bolt that goes thru it has an outside diameter of 11mm it feels that "sloppy" :(
Kind of defeats the purpose of bearings when the pivot rattles around doesn't it?
Thanks in advance for any info...
Feanor
Feanor
