m0rie said:The bike runs strong all thru the range right now, just trying to see what more I can find.
-Maurice
canyncarvr said:Yep, imo the BEL/DDK needles for a #5 throttle valve (oem in most kdxs..yours, too I believe)
canyncarvr said:Any reason you stuck with a 45 for the pilot? I'd be curious if the #1 clip on a CGK is confusing the pilot choice. 45 should be pretty rich,even for 0-500ft.
Looking at your jet profile compared to some I've used (with the obvious 'dissimilar bikes etc' disclaimer) on JD's spreadsheet the fuel delivery of a CGK-1 is hugely wonky...20 'points' high to 1/8 throttle and 30 points low at 1/4+.
canyncarvr said:Skipro:
Don't confuse 'longer needle' with 'longer' L1. The needles aren't any longer, tapers just start in different places depending on the slope/taper/º chosen.
canyncarvr said:I didn't know (or fergot) that your carb had a lower jet block. That will absolutely effect L1 selection. If it's 2mm that's 2+ clips! That would make the CGK make more sense.
What pilot/main did you start with?
re: 'Do you think I should be trying...'
Pretty much. Head that direction, anyway.
You have one of those #9 plugged bikes, right? Are you running that now?
