mafia1989
5
hi im new to motorbikes with gears i normally ride mini motos but i would like a ktm sx125 05 onwards but i need to know how to u shift into Neutral and do you have to use the clutch on a 2 stroke?
Jul 24, 2006
33
I am not sure about the 125 05 and up but on mine i found that the neut.is in between 1st and 2nd gear it can be a bit tricky at times do you have the bike already? if so the manual should tell you or just call the dealer, and yes you do have to use the clutch on a 2t
