Good for you, make sure you take the time to brake in the motor properly. You also might want to regrease the bike, check out the site on the first post at the top of the page. Then take a look at the tech tips section. Good Luck!!!
I have a new 03 200 also. Check the new bike set-up site and definately grease the swing arm and rear shock mount. If it's like mine was the swing arn has a little grease, but the lower shock mounting arm with 4 sets of bearings did not have any grease in it. Raise the bike up on a stand and you can pull all of the bolts out and fill the bearings full of water proof grease in about 1 1/2 hours. You don't have to do anything to the rear shock once the rear tire is off of the ground. At some point, you will need to get the steering head bearings greased also. Even with this little inconvenience, this is a great bike and I'm sure you will enjoy yours. Congratulations
