scottwagnermd
- Nov 30, 2004
- 18
- 0
Well, I just put in a 48 pilot (great service from TT store BTW) instead of the stock 50 on 2004 yz250. bike was fouling plugs like mad. happened to disconnect the tps sensor during carb disassembly. it was my first time into a carb and i won't be making that mistake again. will check it with a multimeter soon but it was marked so i was able to line it up fine.
here's my questions. bike sounds great, but it's running what sound to be 1/2 max rpms. i thought it might be just the carb cleaner and let it run for a while and it never slowed down. i screwed the idle screw WAY out to no avail. on a positive note, i do get some change in idle speed with the fuel screw, which i didn't before. my jetting is otherwise stock, new plug, checked for any leaks and carb is firmly in position. not sure i have the two nuts on the throttle cable on top of the carb adjusted properly...can you change idle speed with those like a clutch adjustment? i also sprayed through my new pilot jet with carb cleaner, but didn't have any compressed air. i don't think that would plug a pilot jet.
i'm going to disconnect the tps later and see if that makes a difference, but i don't think that's th eproblem. i am wondering about the throttle assembly and i'm going to go out and tear the carb apart again if none of you guys have any other ideas. Thanks so much.
cheers
cheers
