Well i just bought a kx250. I had an old 4 stroke and wow are these different. anyways, here is my problem:
1. I believe i have weak compression because i can push the kick starter down with hand pretty easy, but it does start easy when i do kick start it.
2. It runs good but will sometimes bod down a little in the mid-high rpms which i believe this is the carb as it would be on a 4 stroke.
3. If i let off the throttle and pull in the clutch it wil stall easy (just let clutch back out to turn engine over and it will fire right up). maybe also carb or is it normal for 2 strokes?
4. The engine sounds ok (no rattling or any odd noises) so what are the chances of just putting in a new piston/rings etc...?
sorry for the long post i just want to ride, thanks
