This is a pain in the arse. I am trying to adjust my chain per the KDX service manual an it states the clearance should be between 2.2 to 2.8 inches.
The first setting at notch 3 gives me 2.55" at most points on the chain except for the tightest spot which is 2.3" clearance. Too close to the bottom limit.
The second setting at notch 2 gives me 2.8" at most points on the chain except for the tightest spot which is 2.5" clearance. At the top limit!
Which do I use? The notch 3 setting looks right but I'm afraid it will snap at the tightest point.. The notch 2 setting leaves the chain very sloppy to the point it looks like it could fly off if I gunned it.
