padrutt199
- May 22, 2001
- 219
- 0
can you run nitro methane in dirt bikes
Let's forget about the mechanical differences required for each fuel for now, and just deal with the mixture issue. If you simply dumped the gasoline and poured nitro in your tank, the bike wouldn't even run, much less make more power. Nitro actually has less btu content than gasoline. The reason an engine can be made to produce more power with nitro versus gasoline is because, for a given volume of fuel/air mix, the nitro mixture will contain a much higher percentage of fuel than the gas/air mix. Gasoline burns best at a ratio range of 12-14:1 fuel-to-air, while nitro burns best at a ratio range of I believe around 6:1 fuel-to-air, or roughly twice the fuel with half the air. Obviously, you ain't gonna get the two different fuels to work with even remotely close to the same jetting, maybe not even the same carb. I don't really know about using the same carb because I've never ran nitro in anything that I have owned, due to the very high price tag. I don't think I want to pay $100 a gallon for fuel for my bike.Originally posted by padrutt199
at a race could i run regular gas in practice and then put the nitro methane in at the main event without hurting my engine i just want to know because it would make it really fast i think
