Here is my problem. I have to press way far down on my rear brake pedal in order to lock up the rear wheel. And when I bleed the rear brakes oil just trickles out of the bleeder screw. The oil should come shooting out like from a cannon. My return spring is working,the pedal is adjusted to the right height(level with top of foot peg). I have dot 4 fluid installed. It could be 1 of 2 things or both. #1 dirt in brake line? #2piston is junk in the master cylinder? I just put knew rear pads on and notice it getting worse before I changed them. The old pads were way over due in changing. I don't have a oil leak beacuse the resivor is full. Any help is greatly valued.
Any leads on parts would be great thanks.
98 kdx 220
98 kdx 220
